freezer not cold enough
Freezer won’t get cold enough. Freezer runs and runs, ices up on the inside. What should the temp be at for an upright freezer?
Here are your parts, includes a wiring diagram
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=mfu14f3gw5
Temperature should be close to 0 degrees F.
Check that the evaporator fan is running.
Check the condenser coils on the back are clean.
Check that the door is sealing properly.
Next, remove the evaporator cover in the freezer so you can see the coils.
Do not let them de-ice.
If they are heavily iced/frosted over you have a defrost problem.
If yes.
Manually force a defrost cycle by turning the defrost timer cam (Item 23 in Section 3) till the fan and compressor turn off.
Now check the defrost heater to see if it is on.
Be careful you do not want to burn your fingers.
If the heater is on then the timer needs replacing, re: it is probably stalling during it’s rotation so is never getting into a defrost cycle.
If not on.
Unplug the unit.
Remove the wire for one side of the heating element (Item in Section ) from the wiring and measure it for continuity, usually around 20 ohms or so.
If the heater is OK
Remove one wire to the defrost thermostat (Item in Section ) and measure it, should be 0 ohms when frozen. Note that it opens just above freezing so must be frozen to check it. Also inspect it, if it is bulged at all replace it even if it measures OK.
If both the above are OK then odds are the defrost timer contacts are toast.
Best way to test this is a live test to see if you have 120 volts across the heater/defrost thermostat combo.
  1. Always remove power from the machine otherwise you could blow your meter.
  2. Always disconnect at least one side of any device you are checking. This eliminates the possibility of measuring an alternate/parallel circuit path.
  3. When checking for closed contacts and continuity use the lowest scale (Usually 200 ohms). Then try higher scales. This scale is 0 to 200 ohms so if the device you are measuring is 300 ohms this scale would show an open circuit which it is not, you are just measuring outside the scale’s dynamic range.
Thanks for the information, I’ll give it a try.
This morning the freezer was still running and it was at -2*, I turned the dial to almost off and the freezer shut off when I turned the dial back to the on postion it started at about the number 5.
I reset the dial to 3 and no start.
I did replace this timer about 1 1/2 years ago, do the timers go out like this frequently?
No, but the timer may not even be your problem.
Your freezer temperature should be lower than -2 degrees if it is running constantly. Without specific, accurate digital temp measurements, I would suspect a small refigerant leak or a worn compressor. Will probably need a pro. to look at it.
