Freezer problem
[LEFT]I seem to have a failure of the defrost system. The back of the freezer is all iced up, but temperature is high in refrigerator and freezer. I have changed the defrost thermostat. What can I do next?
[COLOR=#000000]Thank you!
[/COLOR][/LEFT]
Hi.
Did you check the defrost thermostat before replacing?
Check the defrost heater for continuity. If it’s open - replace it.
If both - thermostat and heater checks OK - then most likely you have a bad control board (located in the refrigerator inside the control panel).
The defrost heater 67002493
The control board [part]12868513 [/part]
Here are the breakdown diagrams and Replacement parts for Maytag ABB2522FEW11 REFRIGERATOR | AppliancePartsPros.com
Thank you. Post the results.
Simon.
Thank you Simon,
Where the evaporator is located?
Do I need to open the back or do I need to open the freezer section.
Hi.
The defrost thermostat you replaced is located near the heater at the evaporator coil.
Simon.
Hi,
I remove the conectors of the defrost heater and got continuty. but my question is "do I need to remove the heater from the freezer in order to tested?
Thank you
No you don’t. You already tested the heater.
Simon.
