Freezer works, frig is warm - evaporator core keeps freezing
We currently own a bottom freezer refrigerator than is a little over 9 yrs old. Two wks ago we noticed the frig temp had risen to 60 degrees while the freezer remained functioning & all food still frozen. We turned the unit off, took the freezer section apart to find the evaporator core frozen solid. Please note per the instruction manual, both frig & freezer are set at #4 for temperature functioning. Neither frig nor freezer are overloaded. We thawed out evaporator core w/ a hairdryer, reassembled & it has worked great for 2 wks. Woke up today to the exact same problem. What is causing the evaporator core to ice over? Is there a thermostat that is perhaps bad? Please advise. We can’t keep losing all our food & are frustrated. Has been a problem free appliance until now. Thank you
Here are your parts, includes a wiring diagram
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=ARB190ZCW
First remove the evaporator cover in the freezer so you can see the coils.
Do not let them de-ice.
If they are heavily iced/frosted over you have a defrost problem.
If yes.
Manually force a defrost cycle by turning the defrost timer cam (Item 12 in Section 3) till the fans and compressor turn off.
There is usually a hole in the control console to let you do this with a screw driver.
Now check the defrost heater to see if it is on.
Be careful you do not want to burn your fingers.
If the heater is on then the timer needs replacing, re: it is probably stalling during it’s rotation so is never getting into a defrost cycle.
If not on.
Unplug the unit.
Remove the wire for one side of the heating element (Item 15 in Section 4) from the wiring and measure it for continuity, usually around 20 ohms or so.
If the heater is OK
Remove one wire to the defrost thermostat (Item NI in Section 4) and measure it, should be 0 ohms when frozen. Note that it opens just above freezing so must be frozen to check it. Also inspect it, if it is bulged at all replace it even if it measures OK.
If you let the unit defrost you will have to hold it’s face onto s ice cube, just be very careful that you do not get a shock. You could also freeze it in another freezer if there is one available to you.
If both the above are OK then odds are the defrost timer contacts are toast.
Best way to test this is a live test to see if you have 120 volts across the heater/defrost thermostat combo.
  1. Always remove power from the machine otherwise you could blow your meter.
  2. Always disconnect at least one side of any device you are checking. This eliminates the possibility of measuring an alternate/parallel circuit path.
  3. When checking for closed contacts and continuity use the lowest scale (Usually 200 ohms). Then try higher scales. This scale is 0 to 200 ohms so if the device you are measuring is 300 ohms this scale would show an open circuit which it is not, you are just measuring outside the scale’s dynamic range.
