Model manufactured 2014, a side by side. Leaking from freezer onto floor. I have unplugged, defrosted and removed back panel of refrigerator. Here are my questions; 1) What is causing this? More importantly how to solve problem? 2) How do I remove the freezer’s inside back panel to access the drain hole? There are no screws. There are 6 arrows on the panel. I have tried a screw driver and putty knife and tried to pry the panel off, but no luck. Do I have to remove the upper panel first? If so, how do I remove the upper components-- ice maker and water line, if so, how? 3) Fill in with any other directions. Thanks
Related topics
kenmore freezer back panel | 1 | 2550 | April 26, 2009 | |
Freezer Back Panel Removal | 1 | 3351 | June 5, 2011 | |
removing rear panel in freezer | 1 | 1610 | July 14, 2011 | |
Remove Freezer Back Panel?? | 4 | 9951 | March 3, 2012 | |
Removing bottom panel of freezer | 1 | 2294 | September 6, 2012 |
