Fresh food door does not seal tight
Fresh food door does not close tight, is there an adjustment? I have check all around the door and seal area. Freezer door snaps close tight.
You will need to call into APPros to discuss this problem… It may be you will need a new closure AP317021 but call in to make sure that this is the right one for your model… The diagram I looked for was not available but the parts list was… They did show the freezer door diagram…
