fridg. diswasher just quit
dishwasher just quit…idle now for 6 months…
water supply good…power good…
doesn’t appear to have a reset…
Absolutely nothing is going on with the unit…
Remove the toe panel and check the power cord connection to the dishwasher for a burned wires and/or loose connections.
Gene,
I did that…the dishwasher is connected direct to my breaker box…
connections are good, nothing frayed or burn’t…breaker is not tripped
what i need todo is get a unit to check to insure that there is power at this connection…control panel is blank…i tried the the test run…and the release to make sure no one locked the board.
whats is next.
thanks fro the quick response,
ml
I meant the dishwasher junction box (20 on the break down diagram). Did you check that?
Next step is to remove the inner door panel and check the door latch switches.
Water dispenser was intermittent, when ice disp. depressed lights dimmed and the fans drug down. Researched other posts, found to be a bad main board. Thanks again.
