Fridg Not Working
MODEL # MFI2569VEM Display panel on ice maker has gone out. If you press any key, all the keys light up and beeps. As soon as you let off, all keys go blank again. Refrigerator lights are on, but not cooling or freezing. Tried unplugging to reset, but that did not work. Is the control board behind the display pad the problem or should I check elsewhere? Thank You.
