Fridge/Freezer Not Cooling, Compressor Hot
My refrigerator and freezer stopped cooling this week. I unplugged it for a day and plugged it back in and it still is not cooling.
[LIST]
*]It is receiving power - lights on and fans running
*]Condensor clean
*]Adjusting thermostat does not make a difference
*]Compressor makes a slight humming sound and is hot[/LIST]Should I test the relay or other parts, or if the compressor is on but it’s not cooling does that indicate an internal failure and it needs to be replaced?
Thank You
Pry off the side cover on the compressor and remove the black ptcr device. If it rattles when shaken, it’s bad, order a new one AP3601983
Make sure when you replace it to add the run capacitor, a black item. Good idea to take a picture of wire placement.
