Fridge leaking
Hi I work for a maintanence company lately we’ve been having problems with fridges leaking. sometimes the freezer is full of ice and the drain is frozen.we’ve seen this in Whirlpools and Ropers we defrost them manually
check to make sure the drain is not clogged and check the bi metal def. its seems to look ok any ideas would help :confused:
thanks I’ll give it a try
