I have a Samsung RS267LASH and the refridgerator side does not seem to be cooling. I’ve read everywhere that they have a ton of defrost problems and I think this may be the case with mine. My question is…the "fresh" bins with their own temperature control seem to get cold. Is there something I’m missing here, or something I should check?
B
I have exact the same problem that your having on the same style fridge RS267LASH, if you would happen to fix it let me know what you did so i can do the same, and in return if i correct my problem i’ll post what i did to repair it, Thanks
I repaired my Samsung RS267LASH, my symptoms was the freezer was staying cold, but the fridge was not, i pulled the inner panels out, and done some resistance checks on thermistors, and the defrost sensor, and found it to be open, there was a total of 4 sensor in the fridge, and if they are check there should be some value showning when you use a multimeter, i replace the thermal switch, and all is working like it’s suppose too
