fridge woes
my fridgidaire 8-9 cf fridge freezer… the compressor is running hot and seems to be running all the time. I changed the defrost timer but its still doing it.I played with the screw on the front of the timer too… you can get it to stop if you keep turning the screw or turn on…that timer seems to get hot too.
I wired it correctly because it worked when I plugged it back in… the wiring is different from the chinese style but the info is available in the web…
Its 8 years old but only use it 7 months a year. FRT 045GM.
Should the compressor ever run hot??? I dont use the freezer compartment and would like to shut off the fan up there but I dont know how…
I have a separate freezer downstairs and I was thinking …would it be better to get a fridge only,no freezer section, and would that last longer since I dont need a freezer compartment…??
If I have to replace this what would be a good fridge only 12-14 cf that I could get under 400
dollars…
