Anyone know what might cause a hardly used 2 1/2 year old Fridgidare microwave to stop working? I don’t have the model number with me as the microwave is in another state but it is an over range type. When I set the timer, press start, the light on the inside comes on the timer starts counting down but no microwave is happening. :mad:
The first thing I would do is open the control panel and check all door switches for continuity according to the wiring diagram.
Here are the break down diagrams for the Frigidaire microwave http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=1305355&&model_id=5155824
Good job. I’m glad you were able to fix it.
I have the same problem with my MW. The light and timer start but no motor sounds and no turntable movement. Thought the door switches would be easy to check, first.
I opened up the control panel, unhooked wires on all three Door Switches and removed the Latch Hook containing the switches. I took a 9-volt battery and used a multi meter to test each switch. I get voltage on all three.
Unless I didn’t do it right, it seems the door switches are fine.
What should a test next?
Position #, Part #, & Description from the manual
37 5304440289 Latch Hook
8 # 5304440026 Switch, sec. interlock, door
9 # 5304440027 Switch Kit, monitor, with CT fuse
I have the same model being discussed - FMV156DBB. Any thoughts on next steps?
I finally broken down and called a repairman. The door switches were the problem, but none of them had failed. They just needed adjusting. $110 later, and we have the popcorn maker back.
please please help me. i have Model FMV156DBB over range microwave and turn table wont start and no heat, light comes on and punching numbers work i can punch numbers and it starts counting. can you please tell me how to test door switches i have tested them and i have little knowledge about this stuff they seem to work but i am scared, i am doing it wrong. what should be readings on this switches? thank you 270 792 8810 thats my phone number if you have time please call me.
— Begin quote from nismax;232126
If you do not feel comfortable testing the microwave, the best way is to call a pro.
please tell me what should reading suppose to be top one and two on bottom. thanks call me please
The top and one of the bottom switches are Normally Open, what means there should be continuity between their terminals with the door closed and no continuity with the door open. The third switch is the monitor switch and it is Normally Closed. The readings on it should be opposite.
