frig/freezer not cooling
had power failure and now frig/freezer not cooling. compressor and fan comes on for several seconds then stops? :confused:
Hi.
First of all you need to check the model number. It most likely is the PLHS267ZDB5 and if this is the case you may have a problem with a Adaptive defrost control board or the Cold control. If the evaporator fan motor runs without interruptions while the compressor and condenser fan motor are short cycling, the ADC is faulty. In case if both fans and compressor are acting up, then the freezer cold control is bad.
Here are the breakdown diagrams and parts list for your refrigerator:
[MODEL]PLHS267ZDB5[/MODEL]
The Adaptive defrost control AP4909015
The freezer cold control AP5949252
Good luck. Please keep us posted with the results.
Thank you,
Simon.
