frige not staying on
This side by side,with ice maker(not hooked up) stays running for about an hour then shuts down. The controle module was replaced,4 mounths ago.There is plenty of sirculation in the freezer.when you open the freezer door,& leave it open it turns on,but runs temporarly(compressor is warm,fan runs,coils are working too…At first thought it was the fan motor,checked for power to it-ok.Then i rapped on the controle box in the fresh food section,& it went on.thought i fixed the problem tell i learned at midnight otherwise…Can someone help? Thank -you:confused:
Hi.
Most likely it’s a bad freezer cold control (left one )
[part]5304421067[/part]
Use the old plastic sleeve.
Here are the breakdown diagram and Replacement parts for Frigidaire FRS26R2AWB Frigidaire/refrigerator | AppliancePartsPros.com
Thank you. Post the results.
Simon.
