Frigidair affinity gas dryer error E56 032
My affinity gas dryer has suddenly stopped drying, runs but no heat. Sometimes it stops with the three lights above start flashing and err in LCD.
Following posts here got the error code.
Revision is 06
Error code is
E56 032
Any help is appreciated.
Mike
I do not see an error E56 on the tech sheet. There is an error E5B which is heater fault. Set timer to normal cycle and temp to high heat, press start and check voltage across control board relay RL2 (leave wires connected). If you read 120vac, then the board is bad. If you read zero, you need to troubleshoot the heater circuit components.
Eric
