Frigidaire Affinity Washer door won't close
i have replaced the door boot on a Frigidaire Affinity washer. The boot is fully installed, all springs are in place. The door will not close. It is catching on the boot at the bottom. I have verified the boot is seated all the way around. Any suggestions what I should check or change?
I am curious, why did you have to replace the boot on such a young machine?
Was it the door possibly being out of line that caused the first boot to go bad?
If the door is sagging then this may be the problem.
