I ordered the replacement part for the water valve/Dispenser/NTC/Short Tube. There are three locking plugs in the water valve harness that connect to part I need to replace.
I’ve found the repair manual online, and it simply notes that these are locking plugs. I can see that there is a small ridge that is part of the locking mechanism, but even after lifting the plug away from that ridge, these three plugs do not want to come off.
I’m hesitant to apply too much force trying to remove them.
Does anyone know if there is a "trick" to disconnecting the locking plugs from the part so that I can replace the part?
It’s a frigidaire washer model-fleb8200dso and it’s a small hole in the back of the washer. It icomes out a little but not all the way. Do i continue to try to pull it
There are no screws in the back to take off. So how do i get it out?
