Frigidaire Broil element fails to heat
When trying to turn broiler on either high or low power, the light over the broil button flashes the display reads HI or LOW. A few seconds later there is a click, the light over the broil button goes to steady on and the display shows current time. The broil element never heats up. I’ve checked the element and it seems good, so I’m now looking at the control unit. Could you offer any assistance?
When you say, you checked the element, did you ohm it our or look at it? If you ohmed it out and got a reading it is good, if you did not get a reading it is bad. If the element checked good, you need to replace the clock control board. Tom http://www.applianceeducator.com/parts.htm
