Frigidaire Dishwasher not washing
The water comes into the dishwasher but does not spray. It sprayed 2 times and just quite. It just pumps water in and out and the heating element does work when it is drying. The spray arms are clean and nothing in the holes. The motor doesn’t seem to make any sounds. Before, the connection was loose that went into the motor but I pushed it in and it worked 2 more times then stopped completely. Any suggestions?
Hi.
Are you ready for a simple test?
Disconnect two wires from the motor and using voltmeter check for 120v across this wires while the timer calls for wash. If there is 120v - replace the motor. If not - check the wires. Wires OK - you have a bad timer.
The motor AP5272391
The timer AP2109592
Here are the breakdown diagram and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=120402
