Frigidaire Dishwasher not working
[LEFT]I have recently purchased from you the control board and selector switch board for my Frigidaire dishwasher model FDB1980RGQ0 and serial # TH74116903, but it still does not work. I am getting very frustrated.
Let me start at the beginning. One day it just stopped working. I pulled it out and turned it on it’s side and I noticed a burnt electrical connector. It was connected to a thermostat, there are two, this one is on the left if you are looking at the machine upright from the front. It seemed to be an obvious problem but I replaced the thermostat and redid the wire and the machine still did not work. After reading several of the question and answers on your site, I decided to replace the control board. It still did not work. I then decided to replace the selector switches because I read on your site that they are often replaced together. It still does not work.
It does however give me what must be an error code. The Drying, Clean and Sanitized LEDs flash in unison. If I shut the door the upper rack light also flashes. If I push the Start/Cancel button then the Lock LED flashes along with them, but only as I am holding the start/cancel button down.
I tried to do the self test according to the directions found inside of the front door, but it does not seem to do anything. When I push the buttons I can hear something on the control board click but the machine does nothing. I thought that maybe the machine was just not filling with water and that maybe if I put water in it it would start, but nothing happened. I filled it until water was about to come out the door.
[COLOR=#000000][FONT=verdana,geneva,lucida,‘lucida grande’,arial,helvetica,sans-serif]
Read more: http://forum.appliancepartspros.com/dishwasher-repair/462254-frigidaire-dishwasher-doesnt-do-anything.html#ixzz1rlw27Jq0
[/FONT][/COLOR][/LEFT]
Check the door switches. Make sure they are properly engaged when the door is locked. If there is something wrong, replace the door lock assembly.
