frigidaire dishwasher
Have replacement part for soap dispensor.Have taken screws off of door. Door not coming apart? How do I get the door apart, so I can insert the dispenser. Will I have to replace the gasket around the door once I seperate the door from the frame? Thank you for the help. purple
Open the door and remove all screws on both sides of the door. Close the door and slide the outer door panel down to release the top of it from the control panel. There are no gaskets.
Here are the break down diagrams for the Frigidaire dishwasher http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=345162&&model_id=109322
