Frigidaire doing weird things
Recently started having these issues with the washer.
If I press on Quickclean, which is a 50 minute cycle, and hit the start, the timer will start at 1 minute and then it will go up to 8 minutes and start drying and then it’ll stop with a "Clean S" indicator. It shows the "S" even though I never press the "Sanitize" option. So instead of the timer counting down, it goes up.
When I open the door after it says "Clean S", "PF" starts blinking. When I shut the door and open it again the "PF" flashing disappears.
What’s going on here? Help is appreciated.
