Frigidaire Door Stuck
Frigidaire Gallery model FTF530FS washer door is stuck. Unplugged it, opened up the bottom panel, opened up the top panel and couldn’t see or feel any way to manually open the door.
When I gently push/pull at the door the maglock clicks open and closed so that isn’t the problem.
Pulling hard at the door just starts to pull the outer door (part AP4455026 off.
The problem appears to originate in the door lock assembly (part [URL="http://www.appliancepartspros.com/Appliance-Parts/frigidaire-door-lock-assembly-item-number-ap4455026.aspx)) but how do I access it? Should I pry the door off and hope for the best?
Trish
