frigidaire door switch
I am trying to see if I can get a door latch assembly or just the solenoid for it. Mine melted and stuck the door shut. The online picture in the cabinet parts shows it in the center of the cabinet. It fastens on with two screws and has 6 wire to it.When I go to look at a picture of it it is showing me something that looks like a weight assembly. thanks.
Frigidaire redesigned the door latch assembly. The new assembly included the installation instructions.
  • The part number for the door latch assembly is AP2578357
Here are the break down diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=356248&&model_id=116131
Thank you so much for the info on the door latch. I guess it would be helpful if there was a notation on the parts page that it is a redesigned latch and looks nothing like the old one. Don…
Donfoulk, Just found this thread. Is the door latch assembly difficult to install?
Gene,
I just found this thread. Is the Door latch assembly difficult to install?
— Begin quote from bruce917;179873
Gene,
What is the complete model number of the washer?
Hello,
I took off the door latch on a frigidaire dishwasher and did not mark where to put the wire back on at. There are 4, 2 black and 2 white. Pls help
MD#FDB641RJB1
Thank you
— Begin quote from RookieJoe;190341
Hello,
MD#FDB641RJB1
Thank you
The two black wires should go to one switch while the two white wires go to the other switch.
