Frigidaire dryer issue runs 10 minutes stops with no heat
I have a Frigidaire electric dryer that will run for 10 minutes stops and the 3 vertical lights on the right side will blink. No heat appears to be coming from the unit. I disconnected the rear tubing and it is only blowing cold air out the back. Any ideas? Help!
