frigidaire dryer
my frigidaire dryer won’t heat up
make sure there is 240 volts coming to the back of the dryer where the plug goes in. flip the dryer breaker off and on a few times, and see if it works. if not it most likely the heating element, and you would have to take the top off, the front off, and take the belt off, and the drum out, to eye ball it. if you have a meter, kill the power, and ohm out the element. tom
