Good morning, and thanks for looking! my Frigidaire dishwasher pump motor shaft seal was leaking badly into basement crawl space. Found out several days later! Big mess!
Ordered new Correct Electrolux replacement motor (same motor but had extra plug connectors for multiple models). Ran perfect one cycle. Second time using it, the motor ran forever afterwards. It cleaned, dispensed soap, heat dried properly but motor kept running. I turned off circuit breaker did a reset as per multiple troubleshooting searches. It did the same thing. Worked perfectly 1st use, second use problem returned. I cleaned very minor debris from tub basket, still has problem. I tried holding the cancel button down for 3 seconds, it just changed heat/heavy/light wash modes around. Is it possible while it was laid on side to replace motor -(as per multiple appliance repair videos!!) - one of the internal float/flood/switch sensors got stuck?
I did a full visual inspection and no hoses kinked, wires or plugs missing/came unplugged. I RE-mounted it perfectly level as the previous installer basically shoved it in, door now closes nicely and adjusted springs. It is only 2-3 years old “lower end affordable model”
(I am a disabled/not working anymore home improvement contractor that has done many similar repairs to other appliances but this has me stumped!
Any help would be greatly appreciated!
Thank you in advance!
