Frigidaire Freezer Not cooling
My freezer will not cool. It only blows hot air. I have checked and replaced the start capacitor, and the thermostat. I have checked the defrost switch, cooling switch, and it still does not cool. I have not checked the freon as it is a sealed system. What could be the problem?:slight_smile:
Is the compressor running?
You can usually hear it but should also be able to feel it vibrating.
I am assuming that since you said it blows hot air that the evaporator fan is running.
If the compressor is running then you have a sealed system problem.
This will be an expensive repair as you need a pro. Usually it makes more sense to put the dollars towards a new unit.
Hi Denman,
Thanks for your post. Thatโ€™s what I was afraid it would be, and yes the evaporator fan is running. Thanks for your help!:slight_smile:
