Frigidaire Front Load Washer Leak
I have a Frigidaire Gallery Series front load washer that is leaking underneath. I pulled the front panel off and the water is coming from the back of maybe the tub. The water pretty much drains as quickly as it runs into the washer. Is this easyish to fix or do I need to look for a new washer?
Hi,
Pull the back panel of the washer off to get a better look and see if you can pin point the leak.
