Frigidaire Front Load washer-Won't rinse or high speed spin
[SIZE=3]Model #= GLTF2940ES1[/SIZE]
[SIZE=3]Frigidaire Gallery Series[/SIZE]
[SIZE=3] [/SIZE]
[SIZE=3]I have read through all the posts and got pretty far, considering I don’t know how to fix much. I ran the diagnostics and got an error 47. I pulled the lock assembly out and tested for resistance and got an 1179. I am not sure if that means it is fine or if it needs to be replaced. I also tested the control panel and got the following readings:[/SIZE]
[SIZE=3]J2=.5[/SIZE]
[SIZE=3]J3=.455[/SIZE]
[SIZE=3]J7=44.3[/SIZE]
[SIZE=3]J14=273.7[/SIZE]
[SIZE=3]J1=54.7[/SIZE]
[SIZE=3]J4=I am not sure if this was reading correct or not. It would not give me a reading unless I put both black and red on the same prong. Then it only gave me a .2. I am not sure if it was saying OL since it didn’t appear to be reading anything.[/SIZE]
[SIZE=3]J6=I couldn’t pull this out to get a reading so I just left it alone.[/SIZE]
[SIZE=3] [/SIZE]
[SIZE=3]At this point, I don’t know what these numbers are suggesting. Please help me with getting the right part(s).[/SIZE]
