Frigidaire Gallery Model 417.39022890 runs through cycle. Water fills and drains. Tub does not agitate/wash and does not spin. I do not have a manual, user or parts.
Use this manual to troubleshoot. Look for problems in the timer, door lock assembly and speed control board (which controls the motor and makes it agitate and spin). Also check the wiring between the door lock assembly and the timer.
http://frigidaireservicetips.com/pdfs/360_TumbleActionWashers.pdf
