Frigidaire FTF2140FS0 won't start
Good afternoon,
The panel lights normally, the door locks (there is a humming noise that gets lower when i pull on the locked door), water supply is OK, there are no clogs on the valve, the switch shows 0 ohms, and the washer won’t start in any settings or temperature. There are some clicks and the humming noise, but water does not fill. Even on the drain and spin cycle nothing happens.
I’m puzzled. Any help is highly appreciated.
All the best!
