Frigidaire Galaxy - Time Switch
How do you wire the time switch on the Frigidaire Galaxy Dryer
I’ve got the wiring diagram — BUT I can’t read it!
Any help please?
Not sure what you mean by "can’t read it"
Is it a poor copy or is it that you find it confusing?
Very confusing to me. I need a diagram saying TAN to B or BLack to A
There is no lettering ABC et et on the switch @ each spot to put a wire
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=GLER341AS2
Below is the timer. If you click on the picture a new page will open with more views and a Q&A section which may help. If you click on the view of the back it shows the connector designations. Your timer is probably laid out the same but there is no guarantee of this so hooking it up using the view is a gamble.
AP2107515
Just in case the diagram you have is different the below is the one that comes up when I search for this unit.
http://manuals.frigidaire.com/prodinfo_pdf/Webster/131850600.pdf
Denman – thanks so much, my problem is solved!
