Frigidaire Gallery Series oven door handle
The oven door handle is held by very short screws. The handle has come apart several times because the screws barely thread into the handle.
I purchased a new handle only to find that new screws were not supplied. Do you have a suggestion for what I can use as a replacement for the factory screws? I need very specific info please. Are these screws heat resistant?
Thanks!:smiley:
Each and every component of an appliance is usually a separate part and would need to be ordered individually. If you order a handle you get a handle, if you order screws you will get screws, etc.
LINK > http://www.appliance411.com/data.php?ap=AP3690487
[QUOTE]what I can use as a replacement for the factory screws?
Similar screws but maybe a bit longer?
The parts list says: Screw handle mtg. - wafer head, 10-14 x 1-3/8
Does that help?
If you want to try to find different ones I suggest you take the originals to a screw supplier and see if they can match up a replacement which is slightly longer. Too long and you may damage the part of the handle it screws into and/or not be able to be done up tight.
— Begin quote from ____
Are these screws heat resistant?[/QUOTE]
No, just probably steel.
JMO
Dan O.
http://www.appliance411.com/parts/?ref411=Frigidaire+Range*The Appliance Information Site*
=D~~~~~~
