Frigidaire Gas Dryer Not Heating
Hey all, I hope you can help me out. I have a Frigidaire gas dryer that will not heat up. I checked all the lint passages, those are clears. I tried running the dryer with wet clothes and without wet clothes. It seems as though that doesn’t make a difference.
I took off the rear panel to check for fuses, but couldn’t find any. Any advice would be helpful. The other thing I should mention is that there is an intermittent noise that comes on. It is a light humming noise, almost as if something is trying to turn on. It seems to come on in certain intervals. It only lasts for a minute or so. Thanks for any help!
