Frigidaire Gas Dryer Tumbling but not drying
My gas dryer is tumbling but not generating any heat. Already read some similar posts and performed some troubleshooting. Began by checking to ensure lint trap and vents were not obstructed. They were not obstructed but I cleaned all lint. Then I checked the Ignitor flame sensor with the ohmmeter. Not very experienced with this diagnostic but here are the readings I got with my digital multimeter:
Igniter = 65 Ohms
Flame sensor = 0.3 Ohms
Based on what I came across on the How to Check Continuity with Ohmmeter post, these look to be good. Can someone confirm my findings? Are there any other parts that I can check/rule out? I noticed other posts mentioned that the igniter glowed - - is there a way I can check this? Thanks in advance for any help.
I usually monitor the current, if under 3 amp=new igniter time, part # above.
Thanks for the feedback, the click was due to the faulty gas coil.
No problem. Thank you for your assistance.
