Frigidaire Gas Range
Hello,
I am running into an odd error and I am hoping someone can help or has run into this. I have a 5 burner stove-top and the center burner (Large one) is having an issue lighting the burner with the electronic starter. I have taken the gas distributor apart and gave it a good cleaning and now if I hold a flame to it, it will light fully. The issue is when I use the spark ignitor, it won’t start the burner (I do see a spark) but then the clock on the stove goes to a "0" display and resets to blinking 12:00 after 5-7 seconds. I believe it may be a grounding issue with the center ignitor as it doesn’t do this with any of the other burners and they also light fine. I have done a bit of research but I haven’t found this exact error. I am hoping your forums will save the day. Thanks for your time.
