was using the oven, temp was set at 400 and right after warming up the stove mad a popping sound, thought I saw something come out the vent on the stove top.
Afterwards:
The clock was blinking two dashes and the setting changed from bake to broil and a constant beeping started sounding.
I turned off the breakers in the basement to the range, just as a safty measure.
How can I make the error code appear again, just to be positive on the error
Any ideas.
I thought at one point I saw an F1 in the clock window too. Going to read the error code post.
Thanks in advance
Tom - Dayton Oh
Well, I guess you found out that the clock control board is the problem on a F1 code. I would just be sure to do some investigating, to make sure there are no burn’t wires, and check the oven elements. Tom
— Begin quote from kayakcrzy;57601
Thank for the reply - I was checking to see if the burners were working and the strangest thing is - everything seems to be working. Clock - door lock mech… bake, broil. As if there was nothing wrong.
Should I still be concerned and let the repair man come on out Tuesday… :rolleyes:
Well - looks like the F1 code has re-appeared, this time permanently. I called for service and the repair(parts) is going to cost me a little more than $350.00 (ouch !!!)
I found the control and the overlay for approximately $200.00. Here are the parts 316220804 and 316207529 locally, about a 5 minute drive from my home. ([B]Dayton Appliance Parts Inc[/B])
Can some possibly explain how difficult this repair could be for me to do myself, if advisable.
Thanks in Advance
Tom
