Frigidaire GLFT1670AS0 will not add water
Our front load Frigidaire GLTF1670AS0 will not add water. I have tried all the different water temperature combinations and all the different cycles (heavy wash, delicate, etc), and the same result…no water.
However, cold water will add if I rotate the dial to rinse.
Any suggestions would be appreciated, thanks!
Mike
Hello . we will need the correct model# in order to help you with the right part numbers, if you will please check that and get back to us we will be happy to help you the model # can be found inside the door usually on the left hand side.
