Frigidaire Ice Maker Won't Turn Off
On this side by side, the ice maker will not turn off, overfilling the bin. I’ve been turning it on and off manually with the power switch. It has a typical trip wire on microswitch; the wire swings freely and you can feel the switch click. Any help is appreciated!
I cannot find any info on the given model number.
Tried here and Sears.
Since it is just numbers I thought it is a Sears unit as they are the only ones that use just numbers.
Please check it.
Kenmore numbers are usually 3 digits, a period and an additional 8 digits.
http://www.appliancepartspros.com/modelnumber_locator.aspx
Ice makers can be a pain to repair and often it is better to just replace it, depending on cost.
I looked again and found this number:
Electrolux PLHS267ZDB2
Thank you.
