Frigidaire - manually defrost
I have been replacing parts, but have not found root cause. The temp on freezer was subzero, and frig was not cooling - replaced temperature sensor, ice maker switch. Read blog, played with damper and loosened it. Coils on freezer have frosted and do not want to defrost (unplugged for a couple of days and replugged in - frosted again). It may be a loose wire as can hear fan turn on when I unscrewed protection panel in back of freezer. Can not find how to manually turn on defrost cycle.
Washer Fills & Pumps Water Out But Will Not Spin Or Agitate?
Take off the front and check the belt. Also your motor has an inverter which has flashing light to signal error codes.
This site here
http://www.appliance-repair-it.com/GE-washer-repair.html
will tell you how to interpret things. First try the re-set process, a lot of times that is all that is needed.
