Hi,
Everything works as before on my microwave but there is no heat and there is a strange smell. I also just replaced the magnetron thinking it was the problem but no luck. One post mentioned that the problem could be a rectifier. If the rectifier is the problem then what is the part number and how difficult is it to locate and change?
Thank you for any help that you can provide.
Scott
