I have no ice, changed the ice maker and still no ice. Checked the following:
- Water fill-tube to ice tray was frozen, now thawed.
- Water dispenser works.
- Checked the yellow connector voltage (left and right valve) and it registered 120V when dispenser pressed.
- Checked the green connector voltage (leff and right) and it shows 0V. However, when I swap the yellow/green connector to the valve, and press the water dispenser, the water flows out of the tubing for the ice.
This led me think that all valves are working…Is this correct?
The only thing I haven’t done (don’t know) is confirm the green connector has 120V when the ice maker turns on the water fill…how do I do this without waiting for the full cycle?
Please help and thanks in advance.
— Begin quote from taberd1985;462646
Dont know why, but lots of people are having problems with blockage at the main water shut off valve.
My problem solved, read my posts.
Hope this helps you.
http://forum.appliancepartspros.com/refrigerator-freezer-repair/245553-whirlpool-ice-maker-wont-make-ice.html
