Frigidaire oven not heating...either element
I have a Frigidaire oven model PLEB27S8CCB that was working fine yesterday but this morning it has no power to either element. The self clean cycles up but no heat to elements. The convection fan works and the control panel has power. I have flipped all the breakers outside and still nothing. Anyone…please help me out. What should I try next?
Hi,
I would check the thermal switch.
http://www.appliancepartspros.com/Appliance-Parts/frigidaire-switch--thermal-item-number-ap2126993.aspx
It’s number 119 in the diagram for your model.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5121612&diagram_id=378971#d378971
— Begin quote from ApplianceJunk;612145
Hi,
[Body replacement parts for FRIGIDAIRE PLEB27S8CCB Frigidaire/electric Wall Oven | AppliancePartsPros.com](http://www.appliancepartspros.com/Appliance-Parts/frigidaire-switch--thermal-item-number-ap2126993.aspx"]FRIGIDAIRE Switch, Thermal, part number: AP2126993[/URL]
[URL="http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5121612&diagram_id=378971#d378971)
We just looked at it and pressed thr reset button but it didn’t help. What should the reading be when checking with multimeter?
The reading should be 0 ohms or very close to it.
— Begin quote from rpdandy;612167
We checked it with multimeter set @2000 ohms and it read 0 but it read 1 when pressing the button.(could not feel resistance/detents when pressing button)
