Frigidaire oven "OFF" display problem
I see someone had this same problem but did not see a resolution.
The oven does not heat and whenever the oven button is pressed the word "OFF" appears on the console display. The instruction manual only says the time of day clock needs to be set in order for the oven to work. The clock is set and keeps accurate time. The stove top operates correctly.
