Frigidaire professional series dw wont stop running
I could really use some help. My dishwasher started not shutting down the other day after it gets done washing. The clean light was on but it sounded like it was still cycling. I have tried to cancel out of the cycle but it still continues to run. The only way to stop it is to turn off the breaker or leave the door unlatched. When i turned off the breaker, the pf light came on but it started back into its cycling again as soon as a i turned the breaker back on. It sounds like the pump is trying to run but the water is drained out at the end. i have ran a whole cycle and it got hot like it drying. I did have a power failure the other day at my house. Thinking it might be the control board. Any help would be appreciated. thank you
Hi.
based on the info you provided the control board is bad
[part]154815701[/part]
Here are the breakdown diagrams and Door parts for Frigidaire FPHD2481KF0 - AppliancePartsPros.com
Post the results.
Simon.
