Frigidaire Range Problems
The clock/oven controls will only come on when I turn one of the elements on. When I turn the element off the clock goes off also. None of the elements will heat up and neither will the oven.
Has anyone encountered this problem before.
My oven just started doing the exact thing you described. did you find a solution?
