Frigidaire Refrigerator FPRH19D7LF1 light always on but switch good...
Hello,
I have a Frigidaire FPRH19D7LF1. It’s a fridge only.
The light inside always stays on. At first I thought it was the switch but as soon as I ordered the new switch, I left the door open and the buzer came on, and turned off when I hit the switch which basically tells me it’s not the switch.
I tried to find a wiring diagram but I haven’t found anything yet. Do you guys have any ideas what it could be? thanks
I’m wondering if the problem is in the electronic control. Stuck relay or maybe a shorted triac.
thanks. yeah. I f I could only find a wiring diagram
I’ve got the same problem.
Own the exact same fridge model.
Did you figure out what the problem was?
Thanks.
Yes. Actually. Looking at the electrical diagram, I figured it had to be the circuit board. Bought one on Amazon for around $100 and, it’s now fixed.
Just to clarify…
Is it the 1) Electronic Control
Frigidaire OEM Part #297326500
https://i.imgur.com/LuAQjWm.jpg
Or
the 2) Refrigerator Controller
Frigidaire OEM Part #216954210
https://i.imgur.com/ptAmbpw.jpg
I’m guessing it’s the first one… since it is $150 vs $20 for the other item.
Thanks.
Yes. It’s the first one.
Even the access is super easy. It’s inside on top. 3 screws I think. The only.part that sucks is that the face that has the writing on it is a sticker. It’s hard to remove it without damaging it. Good luck
