Frigidaire side by side Freezer not Freezing
6 year old, Fridge side not cooling and freezer side not freezing. Replaced dual digit control unit, and that did not do anything. Removed panel in freezer section, everything seems to be working properly there. Any idea on what else it could be? Thank you…don’t want to spend on a new one if it would be an easy fix.
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=PLHs67egsb1
Here is the tech sheet for this unit.
http://manuals.frigidaire.com/prodinfo_pdf/Anderson/240389627.pdf
Is the compressor running, you can usually hear it but should also feel it vibrating?
Is the condenser/compressor fan running?
When you checked the evaporator coils what did they look like?
Was there and even coating of frost or were they heavily iced/frosted over or was the no frost or was there frost in only one area etc?
Was the evaporator freezer fan running?
