Frigidaire side by side refrigerator freezer working refrigerator not cold enough
I have a Frigidaire MRS26LGJ side by side refrigerator. The freezer side seems to be operating normally but the refrigerator side is not getting cold enough. I defrosted the coils in the back of the freezer last night as there was some blockage there in the compartment between the freezer and refrigerator. The fan is working properly in the back of the freezer as well. However, the refrigerator side still sill only get down to about 50 degrees. Checked again this evening. No ice build up. Still not cold on refrigerator side. Any help or ideas I could get for what may be causing this would be greatly appreciated. By the way, door seals are good also.
Shane
did you read the sticky on this?
My dryer works for the first load and after that on the second load and the loads after, it trips the house breaker every 10 minutes. Where should I start trouble shooting the element or the drive train?
Initially, it sounds like the element is heatin up, expanding, and then part of it is grounding to the chassis.
Could also be that the breaker is weak.
